I would like files and folders to move using drag and drop. I updated the command in file types as explained in the help area. As I am dragging the tool tip says "copy". When I release to drop the file, I receive an error that "Windows can not find "Move".. Make sure you typed the name correctly and then try again." Can someone help me with this?
Image of error below
