motie
1
Hi. Is there no longer a Help menu by default? For things like managing license, checking for updates, etc.
I haven't seen it since I upgraded from Opus 12 to 13.
I just factory-reset the "Menu" toolbar and the Help menu did not appear. I was hoping that might do the trick.
I suspect there's still a Help menu, since this article starts by saying to do "Help -> Check for Program Updates": Directory Opus 13.2
Here's what I have on the top level of my Menu toolbar:
Jon
2
By default it's on the Operations toolbar, not the Menu toolbar.
You can also get it via Customise / Default Toolbars.
motie
3
Thank you. I came here to say I found it on the far right of the Operations toolbar, but you beat me to it, Jon.
Thank you. I don't use Operations and probably moved Help to the Menu toolbar years ago. Or it used to live on Menu by default. I don't know which.
I did look for it before posting.
