I'm evaluating Directory Opus, but cannot get viewing for OpenOffice or Microsoft Word to work - I get a hex listing when I click on a .doc or .sxw.
I do not have Word, but installed the Word Viewer as recommended but this made no difference (it is installed OK, I can view the .doc file by right-clicking). I have a full version of Excell installed and viewing .xls files works fine.
Thanks Nudel, your post got me off the mark. Some things in the Active-X plugin could be improved though..
The answer to your first question is "no" - dropping a .doc file on IE caused a download dialog to pop, when I ask it to open the file it opens in a new OO window. I think this is a clue as to why the MS Word viewer is not working - OO is set as the Open action for .doc.
I installed the OO Active-X and then, bafflingly, the OO active X worked in DOpus for .doc files but not for OO's native .sxw files! I fixed this by adding .sxw to the "Handled Files" list manually.
The wording in the "Document Viewers" pane on the plugin config could be clearer - I read it to mean that installing the MS Word viewer would enable viewing of Word or OO files - an explicit reference to installing the OO Active-X would have set me on the right track.
It would be a helpful enhancement if, when you sucessfully try dragging a file onto the test pane on the config dialog it would offer to add that file extension to the Handled Files list.
Hope the above feedback is useful - I suspect you may be losing potential purchasers in evaluation when they think DOpus cannot view OpenOffice files.
