Help plz
am not sure what i done in setting but
clicking on any icons in opus nothing happens will not open any apps
if i click right mouse button and do open it work just fine....
thanks for any help
craig
Single or double-clicking?
Are you trying to launch programs (.exe files) or open documents or something else? Which type(s) and program(s) are having the problem?
double clicking all icons exe
Have you made any changes in Settings > File Types?
Overriding the double-click event on the exe or All Files or All Files And Folders types could cause what you’re seeing, for example.
Adding .exe to the Archives file type group could also cause the problem.
no ive not changed any thing in file types
and the exe is there in file types extension
i see exe application
exe file
Which version of Opus are you on? Please try 13.19 if you’re still on an earlier version.
Does double-clicking the same exe files in File Explorer work?
ive sorted  it ,  i  uninstalled  opus  and  reinstalled it   all   good  now
thanks
craig
