I'm trying to create a keyboard shortcut to open Windows terminal in the directory currently showing in Opus. (Is there always such a directory? I hope so. But I've got stuck at an earlier stage.)
Paths -> (sourcepath) Want Source path (long)? Ah, but of course!
I am afraid that so doing fails to paths containing spaces, even if I enclose the variable within quotation marks:
[error 2147942667 (0x8007010b) when launching `powershell.exe -NoLogo']
Could not access starting directory "D:\Thunderbird mail" "
If I may: it does not help that for existing hotkeys there is no edit button - not even in a context menu; one has to work out that double-clicking the extant item edits it. Oh, except that, also, there seems to be some sort of editing box at the bottom of the screen, even before the double-click:
The edit button: ah yes; thanks. Still, it would be nice to have it in the context menu as well. It is easy to overlook the button because, initially, it is greyed-out, and because it is some distance from the list of hotkeys.
So, that leaves the problem with paths-containing-spaces. Perhaps the problem lies with Windows Terminal, which, I think, needs the path to be sent to it as a literal quoted string. So, how to do that, please, anyone?
The path is quoted automatically if it contains spaces.
Some programs get confused by a backslash on the end of the path, especially if it's quoted. Try using {sourcepath$|noterm} instead of {sourcepath$} maybe.
Adding the $ means the command won't run if there isn't a source path available. Not adding the $ means the command will run and omit that parameter entirely (which would probably confuse wt.exe, as the -d argument would not have any path after it).
The menu in your first screenshot has both versions in the list, and uses "Need" vs "Want" to explain the distinction.
