Help tips pop-up too often during normal usage
The new tooltip, info-popups, usage suggestions are nice and all, but they shouldn't appear
every single time I press a key which triggers it. Its annoying and slows down normal usage.
I can't find where to disable them, but my preference (in order) would be
  1. each possible tip only appear a limited number of times (3 or 4 then its gone forever) (hey, I might learn something)
  2. each popup includes a 'never show again' button, (If there are more than a few tips it gets old really fast.)
  3. Global "disable all tips" (least preferred, since you might add new tips in future to describe new behaviour)
Finally, for tips which have expired (1) or been disabled (2), a button to globally reset tips would be really nice.
Regards
They'll stop showing up once you close them by clicking the cross.
