I use them to change background color of FTP folders (so that it's easy to spot when i'm changing something online)
it's really great...
I also use them to color the background of a zip file
I'd like to add a nice dropbox icon to the background when i'm inside the dropbox folder.
i've used the wildcard path format with regex (C:\Dropbox\*), and it works well except for the fact that it supersedes the zip "folder type format"
Do you have any idea how to cumulate the two formats or to change the order used ?
