I want to create a button to do the following.
I will select multiple files before clicking the button. When I click the button it should prompt me for a string. When the string is entered the button script will check each of the selected file's names looking for the FIRST hashtag (#) character. It will replace the part of the filename for each selected file between the FIRST hashtag and the FIRST dash (-) with the text that was inputted at the prompt. Each file name that is selected will have exactly 2 hashtag characters.
Example:
Selected file name is: AAAA#1234#CCCC-DD-EE.txt
I input: BBB#xxx
The file name will be changed to: AAAA#BBB#xxx-DD-EE.txt
Thank you.
