I have searched information about this function in the manual but I haven't found anything:
The shortcut of The find bar when you write anything in the explorer.
I want this:
Open the find bar whit the shortcut (The bar cleaned)
Paste the text I'm going to look for
lxp
August 10, 2025, 11:01am
2
Try
CLI QUICKFIND noselect:{clip}
lxp:
QUICKFIND
Sry, I don't understand your instructions Can you explain me: Where do I try this? or guide link etc..
Works, but if the clipboard is empty: All instructions are written in the Find Bar How can add IF ELSE statement?
lxp
August 10, 2025, 6:56pm
6
You can use the Evaluator or one of the @if modifiers . An embedded evaluator expression is likely the better approach here, since you'll need to use Clip or ClipFormat anyway.
