Help with HTTPRequest and POST
Greetings.
How can I execute a command using the new HTTPReq object, equivalent to this one (using curl)?
curl http://localhost:11434/api/generate -d '{
  "model": "llama3",
  "prompt": "Why is the sky blue?",
  "stream": false
I tried with:
function OnClick(clickData) {
	DOpus.ClearOutput();
	var Dlg = DOpus.Dlg;
	Dlg.window = clickData.func.sourcetab;
	Dlg.template = "testdlg";
	Dlg.detach = true;
	Dlg.Show();
	var req = Dlg.NewHTTPReq();
	var data = JSON.stringify({
		model: "llama3",
		prompt: "Why is the sky blue?",
		stream: false
	req.AddPostData("", data, "application/x-www-form-urlencoded");
	req.SendRequest("http://localhost:11434/api/generate", "POST");
	var Msg, success;
	while (true) {
		Msg = Dlg.GetMsg();
		if (!Msg.result) break;
		if (Msg.event == "http" && !success) {
			DOpus.Output("status : " + Msg.value);
			DOpus.Output("complete : " + req.complete);
			DOpus.Output("response : " + req.response);
			DOpus.Output("responsecode : " + req.responsecode);
			if (Msg.value == "data") {
				Dlg.Control("static1").title = req.ReadResponse();
				success = true;
			else if (Msg.value == "error") {
				DOpus.Output("error code : " + req.errorcode + "\t; error : " + req.errortext);
	req.shutdown();
HTTP POST.dcf (3.2 KB)
But it doesn't work; I get a "Bad request" response (response code 400). It's likely due to the format of the data being sent.
I've also tried with:
var data = DOpus.Create.Map(
	"model", "llama3",
	"prompt", "Why is the sky blue?",
	"stream", false
req.AddPostData(data);
error code : 7 ; error : Error sending request (10053), response code : 0
And this :
	model: "llama3",
	stream: false
req.AddPostData("data", data); //using other values for 'data' as well
With the equivalent ActiveX object, I can make the request by simply sending the JSON string, without needing to specify a name:value pair (bad thing it's not asynchronous).
Thanks.
We've made this easier in 13.6.3.
Now you can do:
Req.AddPostData("",
    '{"name": "John Doe", "age": 30, "city": "New York"}',
    "application/json");`
to send JSON-formatted data as a POST request.
Now is working as it should. Thank you very much for this addition.
