Hi, I've got a problem with Opus, in the preview window. Word documents, PDF's Notepad files all preview fine. However none of my Outlook 2003 e-mails preview correctly. See below screenshot of what I see in the preview window. I have enabled all the Active-X components in outlook, but I'm getting this same issue. Can anyone please help?
Previewing .msg files requires a suitable viewer on the system. As far as I know there are only two .msg viewers which work within Opus:
[ul][li]The Windows MAPI preview handler, which is built into Windows Vista but not available for XP as far as I know.
[/li]
[li]The Opus MultiView plugin, if you can source the viewer DLLs it requires. This thread mentions some programs which come with the DLLs, though I'm not sure how up-to-date the information is anymore.[/li][/ul]
