Help with Regular Expression
Hello,
I needed a little bit of help using regular expression and the rename command. Hopefully someone can lead me in the right direction. I have a set of file names, actually hundreds, that are named in a specific order. The file names are all listed like this:
Incident NOC ltr (Last Name).doc
All the files have the same file name EXCEPT for the last name changes for each file. What I wanted is to change the order to the following:
NOC (Last Name) Incident ltr.doc
Hopefully someone can help me with this.
thanks
That's simple enough that it's easier done using basic wildcards rather than regular expressions:
Old name: Incident NOC ltr (*).doc
New name: NOC (*) Incident ltr.doc
Type: Standard Rename
