I'm new to Opus and i can't figure out what i need to do with these files. If i add them as buttons they don't function as expected. Can anyone explain what i should be doing.
1. Download the .orp file. Open the Directory Opus rename dialog and set it to advanced mode.
Then select import from the file menu and open the .orp file. You can then add it to the presets
with the add button and give it the name: ยง Layerize
2. Download the .dcf file. Settings -> customize -> drag the .dop file onto the toolbar
