Is it possible to create a hotkey to view a folder in check-box mode? I searched through the commands and arguments in the hotkey dialog and couldn't find it.
Thanks,
Mike
Thanks,
Mike
This command will toggle the checkbox mode:
Set CHECKBOXMODE=toggle
To go to a specific directory at the same time:
Go "D:\Work"
Set CHECKBOXMODE=On
Obviously, change "D:\Work" to your preferred directory.
