Is there a sample script for use Page Control in the custom scripts.
I'm trying to create a dialog with many buttons and edit controls, In the first time, a single dialog works well, until I have added so much functions and buttons and other controls, there is no place for a new control, so I think I need a multiple pages dialog to handle this things.
unfortunately, I still not found a sample script for how to use Page Control in Dialog Editor(also how to scripting).
someone can help?
AFAIK there is no such control.
The closest would be to use Tabs.
An example of a dialog with Tabs (I think it is the only one).
As far as I know there is no page feature in the dialog editor.
Please examine this script for pointers on how to write scripts.
Base (Radix) Conversion - Buttons/Scripts - Directory Opus Resource Centre (dopus.com)
here are instructions on how to install it
How to use buttons and scripts from this forum - Buttons/Scripts - Directory Opus Resource Centre (dopus.com)
Sorry, when I upload screenshot, it always prompt failed. The following is the resource strings of the Dialog when I'm use Dialog Editor.
There is a control named "tab", it is a TabControl while we coding in VB or some other language.
