A while back, I set up a bunch of network drives so I could transfer files back and forth between my Android tablet and smartphone and my Windows7 Prof. 64-bit desktop computer using WebDav Pro and my home wi-fi network. All went well. Recently, when I went to move files from my tablet to my computer, I was told by WebDav that I needed to use a drive I hadn't set up. I thought I remembered how to do this, but I somehow selected Z drive, and although I was able to transfer the files, from then on, Windows keeps complaining about the status of my network drives. I know what I did wrong (I think I should never have selected Z), and I'd like to delete this entry and create the drive properly. However, when I right-click in Directory Opus (v. 11.15 x64), there is no option to delete. All I can do is disconnect. I've disconnected it, but that hasn't helped. The drive right now is listed as 192.168.1.107:8080 (Z:). I suspect that this may be more a Windows problem than a Directory Opus problem, but I'm not sure, and even if it is, I'm hoping that someone may nonetheless be able to help me.
Thanks in advance.
