How do I give mixed custom shortcuts?
Please tell me how to set shortcut keys for folder, flat display, (grouped, mixed, mixed (no folder), off), and click to switch in turn. If you need to add a new command, how to write the command?
You can add hotkeys directly to the buttons:
A button or hotkey like this will let you toggle flat view:
@if:Set FLATVIEW=on
Set FLATVIEW=off
@if:else
Set FLATVIEW=on,mixednofolders
Thanks, I hope to switch these 4 modes by setting a shortcut key. How do I write the set command?
This button or hotkey will step through the four flatview modes:
@if:Set FLATVIEW=On,Grouped
Set FLATVIEW=On,Mixed
@if:Set FLATVIEW=On,Mixed
Set FLATVIEW=On,MixedNoFolders
@if:Set FLATVIEW=On,MixedNoFolders
Set FLATVIEW=Off
@if:Set FLATVIEW=Off
Thank you very much.
