Hello, I am using the evaluation version and getting to know the program. I have two 'problems' at the moment.
The first is that some files and folders on my system have the 's' attribute and should not. For example, I customised the icons for certain folders (using the tools in XP itself) and these now all have the 's' attribute. If I reset the icon to the default, the 's' attribute remains and the description stays red in DOpus. I have found a command in the help file which should do what I want (SetAttr), but I don't know how to use it. Can someone help?
The second problem is that if I right-click on an item in Opus (to get the context menu), it can take up to 30 seconds (!) before the menu opens. The second and subsequent times that I right-click, the menu appears more quickly (even if I click on a different item than the first one) but can still take 3 - 7 seconds. I have tried this on folders with many/few files and with antivirus and spyware scanners turned off, but the delay remains. Any ideas why this may be?
Thanks for any help you can offer. Felixia
BTW, this program is great! I can dump a whole lot of little utilities now that DOpus is on the job.
