In the company we have a normal user (no admin rights) and an own admin-user (local).
With DO I've copied a file from a network share to a sub dir of "C:\Program Files". I've been asked for my local admin user + password and the file was copied.
Other users tried to copy them too (no DO) - but failed with Explorer or Powershell (me too).
With normal user - no pop-up for admin user happens (is this possible disabled in our company?).
With Explorer - it looks like it reads from the network share, admin pop up - enter user - but then refuses to write the file that I need admin rights .. ?
PS Microsoft.PowerShell.Core\FileSystem::\\xxx\0188\groups\DBMS\DB2\Software\JDBC Treiber\JDBC_SQLJ_v11.5> copy .\db2jcc4.jar "C:\Program Files\IBM\SDPShared\plugins\com.ibm.datatools.db2_2.2.201.v20170814_2141"
copy : Access to the path 'C:\Program Files\IBM\SDPShared\plugins\com.ibm.datatools.db2_2.2.201.v20170814_2141\db2jcc4.jar' is denied.
At line:1 char:1
+ copy .\db2jcc4.jar "C:\Program Files\IBM\SDPShared\plugins\com.ibm.da ...
+ CategoryInfo : PermissionDenied: (\\xxx....1.5\db2jcc4.jar:FileInfo) [Copy-Item], UnauthorizedAccessException
+ FullyQualifiedErrorId : CopyFileInfoItemUnauthorizedAccessError,Microsoft.PowerShell.Commands.CopyItemCommand
Problem one is that the local admin user doesn't have access to the network share and problem two the normal user doesn't have write access to "C:\Program Files".
The only workaround would be to copy the files from network share to our local data dir "C:\Data" and then with local admin user from "C:\Data" to "C:\Program Files".
- But how to copy these files without DO without workaround - in one step?
- How does DO copy these files (read with normal user, write with local admin user?)
Thanks!
