I'd like to add EXIF Orientation to info tip when hovering over a JPG-file. IF.. available what item am I supposed to use?
Thanks.
Thanks.
Thank you. Looked into the wrong category. (Metadata). This orientation thing sometimes leads to confusion. Photos show EXIF Orientation right-top (6), in Opus '270'. When converting I should check 90 degrees, i.e. Opus results to '0', which makes me a bit unsure, when sending the photos to someone else, how the receiver will see them.
Anyway, thanks again.
