I'm not sure what this area is called, but I would like to add a few shortcuts here.
You can only turn a few things on and off in that menu by changing the Args field when you edit the location bar.
If you right-click the Parent (aka Go Up) button just to the left of there, that menu is fully editable, and folders can be dragged to it while in Customise mode.
Got it, thank you!
