I have PowerToys Keyboard Manager running. It remaps the [Enter] into [Shift][Enter].
Reason is that whilst exchanging mails from Outlook to Gmail, the replies from Gmail show double line spacing when using just [Enter] in Outlook.
So Gmail 'requires' Outlook users to use [Shift][Enter] to avoid this stupid double line spacing.
The choice is: either adopt this shift-enter or use a keyboard manager.
Regretfully this affects the behaviour within Opus. It will open the 'Go'-bar/box.
Wonder whether the behaviour of the Enter key can be changed without adding a button.
Tried Power Mode : enabling 'Enter key opens all selected files', but did not help.
Why not set it to just remap the key within Outlook? Changing the behaviour of your Enter key system-wide to solve a problem like this seems like a fairly radical course of action
Much has been written about this so-called 'double line spacing'. AFAIK Outlook does not offer a solution.
Regretfully so. One needs to seek for workarounds, like PowerToys or some AutoHotkey script. Yes, it is radical solution, applications like Excel include an optional setting as to how 'Enter' key would behave.
