How to capture keystroke usage in a ListView
Hi, I'm building a script to edit audio file metadata, and I'd like to delete the selected files when I select files in the listView and press the Delete key. I've tried this, but the Delete key press isn't recognized.
while (true) {
    var msg = dlg.GetMsg();
    if (!msg.result) break;
    // Trying to detect Delete key press when ListView has focus
    if (msg.event === "keydown" && msg.control === "listview1") {
        DOpus.Output("Key pressed on control: " + msg.control + " | Keycode: " + msg.keycode + " | Key: " + msg.key);
        if (msg.key === "delete" || msg.keycode === 46) {
            limpiarLista(dlg);
            continue;
There is no event called "keydown"
Here's how to register hotkeys in a dialog using the AddHotkey() method :
Usually, AI tends to "hallucinate" when asked for this type of tasks, which are not "mainstream" (and in fact, I think it does the same thing in everything related to coding.)
Thanks so much @errante, thanks to your links I learned a little more about events and AddHotkey() today. I ended up getting the result I wanted in the following way:
 dlg.AddHotkey("limpiar", "delete");
 dlg.Show();
 while (true) {
     msg = dlg.GetMsg();
     if (msg.event === "hotkey") {
         if (msg.name === "limpiar") {
             limpiarLista(dlg);
We'll add a way to detect keypresses in listviews directly in the next update.
