Dear friends,
- Activate Check-box Mode with applying Set CHECKBOXMODE=On command.
- Checked a file.
- Deactivate Check-box Mode with applying Set CHECKBOXMODE=Off command.
- Repeat phase 1.
As you see, the previous checked file is checked to now. How can I clear checked files every time Checked-box Mode is went off?
Regards
Cris
2
There are probably other solutions, but you could use this code:
Select NONE
Set CHECKBOXMODE=Toggle
Or just add Select NONE to your own code.
Thanks to reply dear Christiaan.
I was tested your code before my question in different situations without any success, but now worked! Thanks again.
Best Regards
