How to "COPY EXTRACT TO=ask" for files inside ZIPs?
I couldn´t find a way to change the context menu for the files inside ZIP files; the “context menu” in the customize section refers to the ZIP itself, not it´s content, & the files inside are obviously not handled as regular files, so changing the context menu for files doesn´t work. So how can i unzip files to specific locations per context menu?
You can't currently change that context menu. Using a toolbar button, menu item or hotkey will work, though.
(The command will be just Copy TO=ask without EXTRACT. EXTRACT is for Zip archives, not things inside of them which are treated like files by most commands.)
[quote="leo"]You can't currently change that context menu. Using a toolbar button, menu item or hotkey will work, though.
(The command will be just Copy TO=ask without EXTRACT. EXTRACT is for Zip archives, not things inside of them which are treated like files by most commands.)[/quote]
Well, in that case, JohnZeman´s nice command would also work:
[After using COPY=ask, how to go to the destination folder?)
I was looking for special ZIP commands where the answer is that simple.
:smiley:
