I would like to add a shortcut to load Microsoft Edge from my Office Toolbar. Thus far I have failed to find the correct path and .exe file in Windows 10 that will load this browser. Any help would be much appreciated.
It seems to be at C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe
To find it (or other things) in the future; open the start menu, and type part of its name to search for it.
Then right-click on its entry and choose Open file location. If this takes you to a shortcut rather than the file itself, right-click on the shortcut and choose Open file location again to get to the real file.
Thanks for your help, Jon. This works, even though the Run: Maximized setting is ignored by the program, which loads in Normal mode. However, if I then maximize it and close it, the next time I use the DOpus icon, it loads maximized. "Sigh. Go figure. Microsoft."
