How to create and display URL shortcuts with their favicon in Dopus?
In Windows 11 Pro, when I create a URL shortcut file with this content in DOpus:
[InternetShortcut]
URL=https://www.gpsoft.com.au
IconFile=https://www.gpsoft.com.au/favicon.ico
IconIndex=0
...and name it GPSoft.URL, the URL shortcut does not display the favicon!
Is there a built-in feature in Dopus that creates a URL shortcut from the URL in the clipboard, as it works with generic text? For example, when I copy the text https://www.gpsoft.com.au to the clipboard and then press CTRL+V in DOpus, it creates a text file "Clipboard Text.txt" instead of a URL shortcut! Why isn't Dopus so smart to create a URL shortcut and display it with the correct favicon?
ClipPaste URL will do this, even for multiple URLs. If you want icons it's probably best to reference locally cached images.
Thanks for the information. However, I don't understand why Windows or Dopus cannot download the known favicon (https://www.gpsoft.com.au/favicon.ico) and automatically use it in the URL shortcut.
One of the true mysteries of modern-day computing... luckily FavIconizer can fill the void.
Probably because Opus is a file manager, not a web browser, and isn’t designed around managing websites and URLs.
