How to define a folder format for specific folders?
I want to define a default format for specific folder.
Example: FTP folder at right panel will Always be viewed as details with two extra columns. Problem is each panel remembers the last folder format which opened at last tab.
I'm sure this is a simple step to fix but i'm lost in settings.
Have you looked at Folder Formats: Detailed Guide ? That explains how to tell which format is being used for a folder.
Found the option i'm looking for from linked thread. All i had to do is turning off the format lock of right panel. Thanks!
