How-to: dual horizontal display without losing focus
can someone post a simple how-to for the following:
using dopus 8.2.1.0 and if my open folder is now S:\ (root of S: drive), when I click on "Dual Horizontal", I would like to keep S:\ in the top and have C:\Temp always open on the bottom half
what happens now is that no matter what folder I click "Explorer" to close out the "Dual Horizontal" mode and if I navigate to C:\Icons, then click on "Dual Horizontal", I end up with top half in C:\Temp and bottom in S:\Temp
have searched what I've done wrong in the config and could use a little help
again, I want the top half if switching to "Dual Horizontal" to stay in the current folder and I want always to open C:\Temp in the bottom half
So you appear to be switching lister Styles... It took me a few minutes to realize that and I couldn't tell if you were trying to describe any part of your problem having to do with your use of the 'Explorer' Style, but as far as just the 'Dual Horizontal' thing goes, I think all you should have to do is edit the 'Dual Horizontal style in Preferences and make sure that:
  • the Folder: check box option on the Left File Display tab under the Style Settings section is deselected.
  • the Folder: check box option on the Right File Display tab under the Style Settings section is selected AND is set for C:\Temp.
That 'should' be it... it sounds like C:\Temp is currently set on the Left File Display tab.
perfect, thank you
