In a button - Advanced
How can I exacute this line?
Go C:\Prg\Office\Dragon\tutorial\enx\built\professional\correction\correction_basics.htm
Bob
Bob
That line by itself should work as-is, although it probably doesn't do what you want it to. It will go to the folder which contains the .HTM file and select the file.
If you want to launch the .HTM file in a web browser instead, the Go command isn't what you want. In fact, you don't want any command. Just put the path to the .HTM file on its own.
What does 'Exacute' mean?
It's supposed to be ex(tr)a cute.
Leo - In fact, you don't want any command. Just put the path to the .HTM file on its own.<<
AOK. On my way.
Thanks.
Bob
