How to exclude certain folders from synchronization (e.g. 'bin'/'obj')?
After lots of manual experiments and research with this forum's search function, some AI helpers, this might be a real bug or shortcoming of the exclusion feature in the Synchronize tool.
Don't get me wrong, it is a great and powerful tool, but I cannot find a way to solve a usecase I quite often have:
I want to synchronize working directories to a transfer/backup drive, but since the directories are mostly code projects and include build directories (LOTS of binary data), I want to exclude certain usual directories with names like "obj" or "bin". But exclusions like
Is there a way to make these mass transfers with directory exclusion based on name patterns?
Bye!
Have you tried bin and obj without slashes or wildcards?
Looks like the deeper nested folders are a problem. Try a filter instead of an Exclude:
location nomatch "*\\(obj|bin)"
Thanks for the superfast reply!
Part 0: In fact I had not yet tested without any wildcards, but just now I can state: It still tries to copy bin/obj...
Part 1: When using location nomatch "*\\(obj|bin)", Opus tells me "No changes detected or required." Unfortunately also not very useful. (I also tried lots of combinations with the filter wizard, to no avail :confused: )
I'm just wondering whether I'm really the first and only person to have a problem with this use case... I mean DOpus is probably used by lots of power users, so I was quite sure I had just a bit too little experience with advanced features and lots of people tell me to do something obvious :wink:
We'll improve this in the next update. Thanks for the detailed report!
Awesome that this will be taken care of, Jon! :crown:
Thanks a lot, this will be a great help both for my day job and my hobby usage. (And I'm sure, also at least for lots of people dealing with software development with build artifacts.)
I think it is fixed now. See here.
