I have a bunch of .iso files.
Whilst filtered and displayed in Mixed (No Folders) or Grouped view I would like to batch extract selected .iso files in their own folder.
If at all possible, how to proceed?
Thanks!
Thanks!
Extract to Sub-Folders will do that. (Assuming it's an .iso that Opus or whichever tool you're using knows how to extract. There are a few different types these days.)
You can also mount .iso files without having to extract them, which is quicker and uses less space. That's built into Windows these days.
Thanks. Correct me if I am wrong, but AFAIK "Extract to sub folders" will create an additional sub folder i.e. not extract in its own folder.
So I need to move the extracted contents up to the parent folder and delete the (empty) sub folder and the iso.
Probably this is not a built in feature of 7zip and can only be done with a script(?), regretfully so.
Mount .iso in this case isn't an option.
thanks again.
In that case, you want the exact example from the manual : Copy EXTRACT HERE
