How to fix default program connections?
Things I have tried so far:
  1. Restarted computer.
  2. Restarted Opus
  3. Reinstalled Opus
  4. Deleted the GP Software folder in both APPDATA locations
  5. Checked for any weird rules in the file types settings.
  6. Reset windows default apps back to original and rebinded them all to the programs I want again.
I don't know how to solve this.
My only way around this for now is to make forced double left click events to open my program of choice. For my most used applications this is fine but to do this for every single extension is not a real solution. Hopefully if other people have similar issues I can narrow down the cause and we can solve the issue!
Please give 13.15.3 a try and see if it resolves the issue.
That did the trick! Sorry windows changed stuff on you guys. Glad you found a solution!
It's particularly hard when they only change stuff for 50% of people and our own machines don't do it :enraged_face:
