I installed Directiry Opus on a new machine, and for fun I wanted to stick with latest default configuration, to see how well it works for me.
It works great so far, all I did was change the default lister to dual view and Power View.
Dual view sticks on restart, as expected, but Power View doesn’t. On every restart, Opus forgets I had Power View on and Details view is active instead.
I tried everything: save default lister, save default layout, but there seems to be no way to make Power View stick. Is this a bug?
It's normally only really two steps: Change to power mode, save the format as the new default. The rest is just in case other settings have been modified and need changing back.
I understand. You are right I only had to change two things: the save for all folders and the remaining check marks in folder type preferences. The other things were turned off by default, but I still wanted to check them and make sure. I counted that as two extra steps
