Is it possible to keep the width of columns in a lister fixed and doesn't change according to the length of the file name?
The following images shows the same lister with long and short file names. and as you see if the file name is long, Name column pushes other column out of screen.
I need to set a width for each column and ask Opus not to change it.
thank you
