I can use it
C:\Windows\system32\OpenWith.exe "%1"
But its performance is different from Explorer.
What should I do?
I need the Explorer effect
Can the official provide this function for DO right-click menu?
I can use it
What should I do?
FileType OPENWITHMENU
can be used on a toolbar or menu to show the Open With menu, including an item which opens that dialog.
I don't know of a command that will show the dialog directly.
Okay, that's the effect I want
hmmm, im trying to hotkey this with ctrl+alt+o, thou nothings happening with a file selected. what am i missing?
generates a sub-menu where you put it on a toolbar or menu.
It won't do anything on a hotkey.
You could make a hotkey which opens a toolbar like a floating menu, and have the command on that toolbar, but there are also much easier methods (e.g. via the file right-click menu, it should be there already).
