I know how to print a listing of the filenames in a folder via Tools\Print Folder. How can I make the listing to be consecutively numbered?
1 Filename_A 2 Filename_B 3 Filename_C 4 Filename_D ...etc.
It's probably there somewhere and I just haven't seen it.
Thanks.
I don't think there is a way to do that directly. However, you can use the Print Folder feature to create a text file or a CSV file and then add the line numbers using a text editor (with macros) or Excel or similar.
Thanks. That would be a nice feature in a future version.
Request features here: gpsoft.com.au/Support.html
I made the request earlier today per the link you provided.
