What is the proper way to pass values to Rename via SCRIPTARG
The docs recommend to pass comma-separated values, but doing so confuses the script and leads to incorrect behavior (not a full error). The only way seems to be to use space-separated values. Or must
SCRIPTARG
be written for each value separately? -
Scripts seem to forget the default values for some script arguments (happened with numerics, boolean seems ok). Passing the value solves this problem. Shouldn't be necessary, though.
