But how I would do it in VBScript doesn't seem so obvious.
It is basic rename scripting, but apparently with a twist.
I have a "strip all before first number" script used to rename episodetitles, and it depends on this functionality as those kinds of numbers isn't a number per se, but really a character.
If you mean for renaming files and it's just a few characters such as spaces and punctuation, then I'd create a button that runs a multiple find and replace rename command similar to the following:
If you mean to replace all the characters within an html document, that's a little different. I just did that yesterday when I went to look up some lyrics to a song and the entire song lyrics were specially encoded by character entities to prevent them from being copied. So what I did was to save the source code from that web page, then copied the character entities and pasted them into a brand new html document and let my web browser decode them for me.
JohnZeman, the intent is to replace ANY numeric entity, i.e %number or &.#number; (without the .) in a filename with its proper character (for instance "&.#65;" = "%41" = "A"). In other words, 00-FF and 000-255 respectively.
In this case it would be too long a road to run Rename pattern as it would mean 512 renames (if one starts from 00) per file, and my folders have 12-500 files each.
If your intent is to do that, then you may discover as I did a few years back when I was writing a script to do the same thing, that what you'll likely end up with is an endless loop and a bunch of files that have totally meaningless names. What I mean by that is each character within a character entity, is in itself capable of being converted into yet another character entity. Since character entities contain & and # the digits 0-9, and the semicolon, you have to treat those characters differently.
In the end I limited my script, which was a script for my text editor so it wouldn't be compatible here, to only the main alphabet characters and certain other characters to prevent it from going into an endless loop.
JohnZeman, as I said initially. I already have the code, but currently in a scripting language that doesn't work with DOpus under 64bit windows (it works with x32 however):
This is the entire section I'm struggling with (it is written in perl, and is part of a rename script):
s/&#[0]*([0-9]+);/chr($1)/ieg;
#Convert hex % symbols to chars.
s/%([0-9][0-9A-F])/chr(hex($1))/ieg;
I didn't mention both earlier because if one of the lines is solved, then the solution for the other becomes obvious.
It is a tiny bit more limited than 00-FF, but covers most if not all chars I've ever encountered in a filename.
Function URLDecode(str)
For i = 1 To Len(str)
sT = Mid(str, i, 1)
If sT = "%" Then
If i+2 <= Len(str) Then
sR = sR & _
Chr(CLng("&H" & Mid(str, i+1, 2)))
i = i+2
End If
Else
sR = sR & sT
End If
Next
URLDecode = sR
End Function
Function EntityDecode(str)
sT = Mid(str, i, 2)
If sT = "&#" and Mid(str,i+4,1)=";" Then
If i+4 <= Len(str) Then
sR = sR & _
Chr(CLng(Mid(str, i+2, 2)))
i = i+4
End If
Else
sR = sR & Left(sT,1)
End If
Next
EntityDecode = sR
End Function
WScript.Echo(UrlDecode("testing%20this%20again"))
WScript.Echo(EntityDecode("and&.#32;again&.#32;and&.#32"))
(Remove the . before & and # in the line above. Added to stop the forum messing with the line.)
The two last lines is just a test of the functions.
It's a lot more messy than perl, but as long as it works..
There was a small bug in the example that leaked through to the above functions. < should apparently be <=, otherwise it won't replace a number/entity if it is the end of the line.
[Admin note: Thanks, I've edited the post to correct it. --Leo]
