Hi, for some time I haven't been able to access the mp3player/tag editor in the viewer pane - all I get for Wavs, Mp3s etc., is Windows Media Player Classic (mediaplayer2.exe in Windows Media Payer folder). Presumably this is because of some decoder I've installed (see attachment) - is there a quick way to restore the DOpus player? I've tried deleting .mp3 from the ActiveX filters and all I get is the file rendered as text. Thanks. WinXP sp3 with WMP 11; Foobar as default player.
In Opus 10, music tags are edited in the separate Metadata Pane rather than via a viewer plugin.
Ah, I had the 'Operations' toolbar turned off. Thank you.
