I have added a button as following:
How can I ask Opus to run this line with admin privileges?
thank you
thank you
Put @admin:
in front of the command.
Million thanks But it doesn't work.
I did some testing:
If I right click and run cmd as admin the following line locks my drive:
C:\WINDOWS\system32\manage-bde.exe -Lock H:
But when I click the following button, nothing happens. The drive is unlocked.
Is there any other way to run a command as admin?
thanks.
I didn't notice you had it set as an MS-DOS Batch Function. If you change the type to Standard Function does the @admin work?
I have 5 licenses of Opus. On one PC it works on two other it doesn't.
I will check the settings to find out what can be different.
thanks again for your support.
