For my use case, I actually want to have no toolbars at all as the default when opening a new lister. However, the only way I've found to change these default toolbars is under Settings / Toolbars / Set As Default Toolbar Set - which I can only do if I have at least 1 toolbar open. Is there any way to set no toolbars at all as the default? Thanks.
If you edit that menu item, you can see it runs the command Toolbar SETDEFAULT.
You can run any command by typing > into the file display to open a command field, then paste or type the command you want to run. That works even if no toolbars are open.
Another way to do the same thing would be to create a hotkey for the command.
