I want to set
\[শিল্পী.* This string in <control halign="left" height="12" name="findWhat" tip="Find What" type="edit" width="130" x="12" y="35" />This Dialog box default value. How can I do it?
For an Edit control, you have to create the dialog and then set the control's text in the script code.
function OnClick(clickData) {
var dlg = clickData.func.Dlg();
cmd.deselect = false; // Prevent automatic deselection
if (tab.selected_files.count == 0) return;
dlg.template = 'Find and Replace Music Metadata';
dlg.Show();
if (!dlg.result) return;
var keyword = dlg.Control('keyword').value.name;
var findWhat = dlg.Control('findWhat').value;
var replaceWith = dlg.Control('replaceWith').value;
if (findWhat == '') return;
for (var e = new Enumerator(tab.selected_files); !e.atEnd(); e.moveNext()) {
var item = e.item();
if (item.metadata == 'none') continue;
var itemKey = item.metadata.audio[keyword];
if (typeof itemKey != 'string') continue;
var cmdLine = 'SetAttr' +
' FILE="' + item + '"' +
' META' +
' "' + keyword.replace('mp3', '') + ':' + itemKey.replace(new RegExp(findWhat, 'g'), replaceWith) + '"';
DOpus.Output(cmdLine);
cmd.RunCommand(cmdLine);
This is my Script code where do I set the text?
Similar to here:
Dlg.Create();
dlg.Control('findWhat').value = " \[শিল্পী.*";
var findWhat = Dlg.RunDlg();
After Read the post I try to write this but it's does not work. Can you help me to solve the problem.
Dlg ≠ dlg?
Ok I have tried dlg instead of Dlg but steel not works
dlg.Create();
var findWhat = dlg.Rundlg();
Can you post your resources (from the first screenshot) in text form?
dlg.Create();
dlg.RunDlg();
<resources>
<resource name="Find and Replace Music Metadata" type="dialog">
<dialog fontsize="10" height="126" lang="english" resize="yes" standard_buttons="ok,cancel" title="Find & Replace in Music Metadata" width="168">
<control height="40" name="keyword" type="combo" width="133" x="14" y="21">
<contents>
<item text="mp3artist" />
<item text="mp3album" />
<item text="mp3albumartist" />
<item text="mp3genre" />
<item text="composers" />
<item text="copyright" />
<item text="Publisher" />
<item text="mp3year" />
</contents>
</control>
<control halign="left" height="12" name="findWhat" tip="find what" type="edit" width="133" x="14" y="54" />
<control halign="left" height="12" name="replaceWith" tip="Replace with" type="edit" width="133" x="14" y="90" />
<control halign="left" height="12" name="static1" title="Find Where [Select Metadata field]" type="static" valign="top" width="133" x="14" y="7" />
<control halign="left" height="12" name="static2" title="Find What" type="static" valign="top" width="105" x="14" y="42" />
<control halign="left" height="12" name="static3" title="Replace with" type="static" valign="top" width="126" x="14" y="77" />
</dialog>
</resource>
</resources>
Ok I do as you say but it's steel not works for me.
it's steel show like that one
but I want the dialog box like this one
where the value is already here. I didn't type each time. But now I can press backspace and can delete this value and type new value if I need.
here is my full script:
// https://resource.dopus.com/t/how-to-find-and-replace-in-composers-and-artist-column-meta-data-in-selected-flac-files/41265/23
dlg.Show();
dlg.Create();
dlg.RudDlg();
' META' +
Here is the resources
<resources>
<contents>
</contents>
</control>
</dialog>
</resource>
</resources>
//?dlg.Show();
//?if (!dlg.result) return;
dlg.Create();
//dlg.RudDlg();
dlg.RunDlg();
' META' +
Hi there is a back slash \ in front of the value. But when I run the button that back slash \ is missing in find what dialog box. Actually it's a regular expression so the back slash \ is must needed. How to solve that?
Notice that the back slash \ is missing in find what dialog box.
But it's should be like that
Backslash is an escape character in JScript strings. To get a literal backslash, use \\.
Thank you so much leo, problem solved.
