How to set a keyboard shortcut for Favourites menu to drop down?
Hi all, I am trying to find a way to give the Favorites Menu button a keyboard shortcut so i can activate it that way. Ideally CTRL+Win+F, but anything convenient will do...
I tried editing the button, but that doesn't seem to do anything:
Editing the hot key button is also quite frustrating since it won't let me choose a letter or ALT to use as a hot key, and I have a (slightly irrational?) feeling that '' isn't detected, even when I specify the left one...
I then had a look in the "Keys" tab, but I couldn't see any other keys I could use, since I don't know which command to use to show me that menu.
Thanks in advance.
-L
That shortcut brings up the Find Computers dialog for me. I have used the shortcut Ctrl + Alt + F and it works as expected.
Thanks, but for some reason, any combination using the WIN key, doesn't work.
How ever, not using it seems to work. Odd...
Alt-A should open the menu, since the label has &a in it:
4a739d62b67de6f21338bd02bb25622677d63433__01
You can move the & to change the accelerator key for menus.
Ahhhhh.... Thanks, I didn't know that the &a had that effect...
