I would like two split the Modified column into separate columns for date and time to improve readability. Is that possible?
Thanks
~Paul
Thanks
~Paul
There are three Modified columns to choose from:
Date/time (Modified)
Date (Modified)
Time (Modified)
So you just need to turn off the first one and turn on the other two.
So far I know, Time and Date are separated on modified column. Right click on a lister titlebar and select more option. Select Date (modified) & Time (modified).
