It minimizes application when it finds a new update or asking again to buy it, those pop-ups going on top of everything. I'd say that application minimizing is annoying...to put it lightly.
You can configure what kind of UI (If any!) the Update Checker displays under Preferences / Internet / Updates.
AFAIK it should never minimise another application, unless that application reacts to focus loss by minimising itself. (Full-screen applications like games sometimes do do that, but it isn't Opus minimising them; it's something they choose to do.)
Opus won't prompt you to buy it unless you're at the end of the evaluation period. At that point it's time to make the choice of whether or not you want to buy it. (If you're seeing that kind of message after buying it, or early in the eval period, that should not happen and we can investigate if you give us more detail.)
It gave me the prompt when it was 23 days until the end of evaluation period. And then 4 days later. And about a week later after that.
Are you using the stock eval licence (the one that comes with the installer & doesn't require any extra actions)
Or have you got an extended eval licence (gives you more time, and is obtained by entering your email address here)?
