How to use [Ctrl+ mouse wheel] for horizontal scrolling in Autohotkey?
Is there a DO command to do horizontal scrolling in lister?
Just tell Autohotkey to send a standard horizontal scroll message to the window you want it to scroll. Same technique should work with almost all windows/programs.
#Requires AutoHotkey v2   ; https://www.autohotkey.com/docs/v2/lib/SendMessage.htm#ExVScrollUp   https://www.autohotkey.com/docs/v2/misc/SendMessageList.htm
#HotIf winActive("ahk_class dopus.lister")
^wheelup::SendMessage 0x0114, 0, 0, ControlGetFocus("A")
^wheeldown::SendMessage 0x0114, 1, 0, ControlGetFocus("A")
#HotIf
Thanks!
But Shift+Wheel only responds to internal functions: Go Back / FORWARD
not work as expected.
Shift & WheelUp::Send "{WheelLeft}"
Shift & WheelDown::Send "{WheelRight}"
"SendMessage" can make Shift+Wheel to work as expected.
thank you!
Shift & WheelUp::SendMessage 0x0114, 0, 0, ControlGetFocus("A")
Shift & WheelDown::SendMessage 0x0114, 1, 0, ControlGetFocus("A")
