I would like to ask how the lock tabs feature can be used. I just updated to the latest version, 12.22 Light edition and I followed these instructions which were found in the manual:
"Folder tabs can be locked in a number of different ways. Primarily, when a tab is locked, it always displays the same folder. To lock a tab, right-click on it and choose a command from the context menu's Lock Tab menu."
Right clicking on a tab did not show me any options to lock it:
I suppose that's it. Thank you for your help.
Would you be so kind to explain the behavior of the Locked tabs? Is it like a pinned tab on a browser without the ability to easily close it?
(Something we have on our list to make built-in in the future. The current built-in purpose of locked tabs is more about keeping them from changing folders, as described in the manual screenshot in the post above mine.)
