You can also use paths relative to the Opus programs folder. (More detail on that in the thread you can find by searching the forum for "alias icons", without the quotes.)
From a quick try it looks like you can also use environment variables such as %ProgramFiles%. I don't think there is an env-var which always points to the 32-bit program files folder but you could create one.
