I can't sort a folder using a button with the command
Set Sortby=Description SortReverse=Toggle
The effect of this command is to perform a reverse sort on whatever column I have sorted on before. The entry in the "Description" column seems irrelevant to the outcome.
When SortReverse=Toggle is omitted, the command does nothing at all, as would be expected, given the above behaviour.
The files in this particular folder are Windows .contact files. My columns are "Name", "Description" and "Modified". Adding further columns makes no difference. The content of each "Description" attribute is one, two or three words.
I can sort on "Description" forwards, and in reverse, perfectly well by clicking once or twice on the heading at the top of the "Description" column.
Am I doing something silly, or is the Sortby command perhaps not designed to sort on the "Description" column?
